Before I throw AC17 out the door because every time I work with the curtain wall tool, I absolutely can never get it to do what I perceive the way things are built…
Now in this case, I am trying to do a trapezoid shape, 36 feet wide, 16 feet on the low side and 25 feet on the high side…the slope happens to be a 3/12 pitch.  I cannot get rid or delete the exterior, in this case the top frames and the 9 foot high frame on the side.
Is this impossible?  I am sure it's possible because I saw someones rendition of the Eiffel Tower using the curtain wall tool.  If he can do that, what am I doing wrong?
How do I move, modify, or delete frames, mullions, transoms?
How do I generate this type of storefront view?  I'll pull my hair out later trying to install doors that never seem to be right…
Pretty frustrated… How can I do BIM if I can't model?
	Dave Olufs
Just 4 Measure, Ltd
iMac Pro 3.2GHz Quad, 32GB, OSX 10.13.6, AC-5, 6, 6.5, 7, stopped for a few years--started again with 12 thru 17, 18 or 19 didn't work, then 20, 21, now skipped to 23.  Started in 1976 hand-drafting ink on mylar...
