Curtain Wall - elevation above current floor
matjashka
The question is absurd, but after checking out the manual and searching the forums:
I'm still lost in how I am supposed to change elevation of curtain walls in plan (v.12)? I can only do it in 3D, unlike with most other objects in AC. This obvious parameter was totally omitted by GS, does anybody know what's wrong with my thinking?
Thanks.
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
4 REPLIES 4
Dwight
If you are right, that is astonishing.
I have been relying on the old "Elevate" command.
Dwight Atkinson
matjashka
Right, there's the elevate command.
Still, the problem is that there's no readout of the current elevation above floor.
Accidentally, I'm dealing with an existing split-level situation and the only moment AC will ask for curtain wall bottom/top elevation is during the creation process, via dedicated dialog box. A half-baked portion of the cake, or was it supposed to work this way, I don't know.
Thank you Dwight
AC 10 ... 26 USA
rocorona
As the CW can have any orientation in the space, (and it can be curved and multi-surface too) I think this is a "wanted un-feature"
Too difficult to say wich point would be the reference for the elevation, after some 3D rotation.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
matjashka
No odometer on my Batmobile...
AC 10 ... 26 USA
