runxel
Curtain Wall misery
Since I ran into this misery again.
Will you ever decide to fix this, Graphisoft?
The last corner of a curtain wall (closed polygon) is totally messed up.
Yes, there is a workaround. But I am tired of workarounds. Software should enable users, not alienate them!
Question time:
Is it possible to have TRUE ROUND segments (yes I totally want bent glass!) in the curtain wall?
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
4 Replies 4
runxel wrote:
Question time:
Not possible, AFAIK.
runxel wrote:
Question time:
Not possible, AFAIK, unless you script curved Panel object, that way it may be possible to achieve.
LaszloNagy wrote:
runxel wrote:
Question time:
For the panels, this may be possible.
But the frames will still be straight.
I haven't played much with curtain walls.
You can have a custom profile frame, but I don't think you can curve the path of that frame.
Carstenem
It would be nice to have a "real curved " curtain wall, saying this it is quite easy to achieve this with other tools.You can look at some of my tutorials if you like, curved windows/glass panels and frames.
Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
