‎2020-08-04
12:34 AM
‎2023-05-09
03:50 PM
Rubia Torres
‎2021-06-04 10:01 AM
Braza wrote:The only material override are the ones visible in both posts from me above, which shows that glass shall be glass - anyway, i could paint it red, the entire panel remains black 😕
Ok... Check if there is any Material Override inside the panel itself.
What is the exact name of the CW Door? I just have the INT version.
‎2021-06-04 10:12 AM
tottoratkai wrote:
Anyway, an Archicad 24 PLA with the problematic element can be downloaded frm here if anyone wants to do some tests, too.
‎2021-06-04 10:33 AM
Barry wrote:Wow! that would solve my problem thanks!
It seems that you have the surface override on for the door panel.
‎2021-06-04 11:02 AM
‎2021-06-04 01:40 PM
tottoratkai wrote:Hey Braza, exactly.
The only problem that i don.t have such a fieldhow could it be?
‎2021-06-04 05:58 PM
‎2021-06-04 06:31 PM
Barry wrote:
As Braza mentioned, you have to Go into 'Edit' mode for the Curtain Wall.
Then select the Door panel and have a look at the settings for that.
‎2021-06-04 07:03 PM
‎2021-06-07 09:38 AM
Braza wrote:That was it.
You could also check Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Curtain Wall Panel Tool > Panel Component Settings.
Perhaps it is set to invisible.
