Curtain Wall not changing panel types
Bruce
I'm pretty sure this is a bug (23.5005):
I've created a curtain wall with 2 panel types. When I edit the wall and try to change a multiple panels from one type to another, the type changes in the selection, but nothing changes on screen. However, if I do them one by one, they change...sometimes.
The only way I can get them to display right is to manually override the surface...which defeats the purpose of having panel types.
See progress screenshots below.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
18 REPLIES 18
tottoratkai
Braza wrote:
Ok... Check if there is any Material Override inside the panel itself.
What is the exact name of the CW Door? I just have the INT version.
The only material override are the ones visible in both posts from me above, which shows that glass shall be glass - anyway, i could paint it red, the entire panel remains black 😕
I couldn.t find other indicators that would change materials.
The problem only occurs if i save the type to favourites and use it from there - which means that the problem could have been solved manually for now... even though not very effectively.
It.s more about the wish to understand how things (don.t) work when they should.
Anyway, an Archicad 24 PLA with the problematic element can be downloaded frm here if anyone wants to do some tests, too.
https://drive.google.com/file/d/1OEN9UKwNK99ndJuWHgOhxWUGUVoFvBAr/view?usp=sharing
[2021-] Archicad 24 5004 NOR FULL / Mac OS 10.15.7 / 3,5 GHz Intel Core i7 / 32 GB 1600 MHz DDR3 / NVIDIA GeForce GTX 780M 4096
[2018-2020]: AC22.6025 Mac10.14.6
It seems that you have the surface override on for the door panel.
tottoratkai
Wow! that would solve my problem thanks!
The only problem that i don.t have such a field how could it be?
You will have to select the CW and enter the "Edit Mode". Then select the desired element and open its settings. You will see it as a drop down menu next to the bottom of the dialog box.
tottoratkai
Hey Braza, exactly.
This screenshot from the previous postis from there, that field is missing for me.
As Braza mentioned, you have to Go into 'Edit' mode for the Curtain Wall.
Then select the Door panel and have a look at the settings for that.
tottoratkai
Hei Barry, see my screenshot from 10:33.
That.s my door panel settings.
PS I just opened Archicad at another machine (also Catalina), trying to find the missing component - the same field missing: It might be a Mac-related bug. Gonna write to Graphisoft.
Thanks for the help guys!
You could also check Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Curtain Wall Panel Tool > Panel Component Settings.
Perhaps it is set to invisible.
tottoratkai
That was it.
Thanks a lot, Braza!!
I never suspected that such an important field could be hidden by default.... but now the sun can shine brighter thanks again!!
