Curtain wall custom frame
Is there a way to put any kind of custom frame in curtain wall
without causing split of panel?
I am trying to model cement panel facade and need to have subframe on every 60cm or less but my panels are way bigger (120x180 cm),
so I need frame that is behind facade panel...
Djordje
No there is not. The panel is only from one frame to another.
You could create a secondary grid, and multiply it manually - not forgetting to edit it whenever a change comes ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
