Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Curtain wall hole
Mario Sacco
Is there a way to create a real hole inside a curtain wall?
I'd like to have real boundary and real panel quantities, not boolean operation.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
10 REPLIES 10
I would probably
1. Rotate the Curtain Wall into an vertical position
2. Do the Boundary Fill subtraction in the Section Viewpoint
3. Rotate the Curtain Wall back to its slanted position
