Curtaion walling inserting a door
I have made some curtain walling using the dialog box but now want to insert a door within but can't seem to figure out how. I have look through all the dialogs in the curtain walling tool and come to the opinion that it is something to do with accessories which i don't seem to have a library for. Any help would be appreciated.
Chris
1 REPLY 1
assuming you're using ac12 (it will help if you add in your signature in your profile waht version of ac you use and your computer spec)
look at curtain wall in index>CW panel settings?
http://www.graphisoft.com/ftp/publishing/ac12_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm
