Curve Roofs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-09-04
09:55 AM
- last edited on
2023-05-23
03:01 PM
by
Rubia Torres
I was just wondering if someone would be able to direct me to the right path.
I have a museum I'm designing and I would like the roofs not only to go from point a to point b with a gradual increase in their rise, but I would like to curve them with their sides.
I hope this attachment will help in knowing my issue more accurately.
Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-04 11:32 AM
Assuming you mean the section is a constant along their length then a complex profiled wall would be the way to go. You could do it with the roof tool but it would take a lot more work and you would end up with a series of segmented or facetted roofs forming the larger roof curve in section. I know what you're thinking but thats just one of those decade old AC wishes that is yet to be fulfilled.
The roof in the top right corner is a bit more tricky as it seems to be irregular in plan so it cannot be done with a simple extrusion. Perhaps the geometry can be broken down into a series of intersecting extrustions? Hard to tell at this scale
cheers,
owen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-04 04:11 PM
Jamie_K wrote:Anything like the objects in the attached image? If so, take a look at OBJECTiVE
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-04 05:46 PM
and I have not been able to find a solution with that kind of roof..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-04 05:59 PM
Perhaps you could try the "Beam Tool" + "Complex Profile"...
Open the AC Reference Manual and do a simple search with these two keywords.
If this wont help... Post an image of what you are trying to achieve.
HTH.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-05 03:20 AM
Though I was more along the lines of having my roof appear like this attachment. I'm not quite sure how I can do that with those shapes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-05 12:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-06 05:16 AM
I did as you said, though when i use the SEO having the target as the wall and the mesh as the element, and do a downward extrusion, the wall doesnt seem to cut.
I hope the attachment helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-06 01:08 PM
Jamie_K wrote:Perhaps something like the attached image - I'm still not quite sure what you're after. These shapes take only seconds to make or change, so it's very easy to explore different alternatives. OBJECTiVE is free for educational use too.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-07 05:14 PM
now I can make a curve roof with different elevation using objective...
Jamie, maybe you must use objective tools to make those type of roof.. you can download that tools...
cheers,
christaline
