Curve corner in Curtain Wall? How?
William Yan
Hey guys, I am modeling a new project. There is a curtain wall which corner is arc. as shown in the pic below. But how can I make this curtain wall corner to be an arc, not like straight line. Thank you !
AC 26 5002 CHI, Windows 10
5 REPLIES 5
You can't make a curved frame unfortunately (unless something has changed that I don't know about).
All you can do is add many nodes for small straight segments that will appear like a curve.
If you look at the 3D of any curved element in Archicad, you will see it is actually made up of many straight segments.
Versions 6.5 to 26
Mjules
Mentor
@William Yan If you want a better shape of the curtain wall's corner, make a copy of it and convert the copy into a morph and hide the original. Use the appropriate palette of the morph tool to shape the corner as you want. You should need a section first to draw the guideline of this corner using the morph tool pen.
Martin Luther Jules
AC 10-26 (Full)
Asus | 64 GB RAM | Windows 11
William Yan
SAD😓
DGSketcher
Legend
@William Yan Form your curtain wall with a square corner. Model the curved frame part as a separate element with the same profile as the boundary frame using a beam. Convert the beam to a Morph. Rotate in 3D and place where required. Use Solid Element Operations to subtract the beam with upward extrusion.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
Or use the Shell 25 object to create the curved boundary frame (then use SEO to subtract with upwards extrusion).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX11.7.10
