We figured it out!
Just incase anyone searches this.
Create a complex wall/add the profile to the wall itself as Laszlo said.
Save the object as an embedded library, file, library and objects, open/select your object. In the first dialogue on the very top (under 3d script) , add ROTX 90. (This can also be ROTY depending on your profile or orientation.
Third, go to the (2d script) and type Project2 3,270,2
This should rotate up, and align any profile onto a vertical surface.
