Yes, I know this topic has been done before, but I can't find the answer I need, so I'm hoping there's an easy solution.
There's a wire railing in the Concrete|Stairmaker folder that I've been using as a railing for balconies, but for the life of me, I cannot figure out how to create such a thing on a curve of any sort. I imagine it can be done with Stairmaker, but I don't want to put it on stairs; I want to put it around a round atrium opening in the floor slab, and around the appropriate places in a curved stair rising through that opening, on one level.
I already have my stairs and their railings, done in ArchiStair. (If I could match or come close to matching that railing, I'd be ecstatic, but I'm also realistic, especially given my complete incompetence at building library parts <g>.)
Is there any easy way to do this, or some library part somewhere that I'm not seeing? It doesn't have to be the exact same railing; just a way to do almost *any* wired railing on varied curves would work at the moment.
Unfortunately, I'm in a real time crunch too, having just realized that I have to put *something* around that hole <duh!>.
What I'd *really* like to be able to do is a curved glass/metal railing, but I realize I may be asking for too much at the moment. I'll be happy with whatever I can get and I'll worry about learning more detailed methods later. If all else fails, I'll just put a plain glass curved wall around it and pretend there are openings if I can't figure out how to cut it at the appropriate places <g>. Or hand draw them in as best I can after I print.
I've got both Stairbuilder and ArchiStair if that helps (although the former confuses me totally), but is there a way to use those without putting in the actual stairs?
Wendy
