Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Curved Window in Curved wall
ratnabhirud
As per attached image I want to insert curved Window in Curved Profile of Wall.
Wall is a Complex profile.
Is there any way except creating custom Window?
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
5 REPLIES 5
rocorona
ratnabhirud wrote:
I don't think. I only know of one horizontally curved window (for "normal" curved walls), but never seen one vertically curved.
For a dirty result, you can try to make a curved CurtainWall, using the "invisible" option for the inner frames.
You can also save it as a window (an horizontal copy of it, laying in the the plan, with the glasses parallel to the x axis).
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
ratnabhirud
Thank you so much rocorona,
Yes, it is good idea that instead of inserting window in Complex profile, we can place curtain wall.
Thanks again for prompt reply.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud
Hi rocorona,
In this post you said that you can place curve window in Curved Wall,
Can you explain via inserting image.
For reference , I am attaching image what I need.
Can you help/
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
You have to to choose metal window from the library.
http://archicad-talk.graphisoft.com/viewtopic.php?p=143456
Also, the search feature of the forum is pretty powerful 😉.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
Hi guys,
I have problem with the windows in the curved wall, because, for some reason... they just curve another direction then needed! and I really tried everythig- to change the face of the wall, to go through all the settings of this windows, to make a corner under particulatr angle.... please help
She or he, had the same problem:
ratnabhirud wrote:
Hi rocorona,
Can you help/
Regards,
Ratna
