Curved curtain wall issue
For some reason no matter what I do, the horizontal frames WILL NOT render as their selected material like the rest of the frame. Is this just a glitch in the script or am I missing some setting somewhere? In the materials pane is has everything listed correctly: Glass material is glass, frame material is wood...
15 REPLIES 15
Stuart Atkinson
It is there in the Aus library.
It is called 'Curtain Wall Curved 11", ie no "W" at the start, so it appears right at the start of the folder (as opposed to the "W Curtain Wall Straight 11", which for some reason has the "W" so it appears right at the end of the folder).
Cheers
Stu
muzedesigns
Oh ok - so it is an Object NOT a window.. That is a big shame!!
Thanks for the assistance Stu!!
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
Djordje
If you have Window Metal Curved in the AUS lib, it can look like the curtain wall - albeit with all the frames and mullions there ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
muzedesigns
Thanks Djordje.. I did try this - but I am trying to emulate 'frameless glazing' .. I just can't seem to get the effect with the Curved Metal Window.. Thank you though!!
Chrissy Avramidis
Djordje
Ah ...
Try reducing the frames to invisible sizes. Or, give them the same material, pen and thickness as the wall.
The last instance is to make a wallhole, and insert a glass wall on a non-intersecting layer.
Djordje
HP Omen
muzedesigns
I will try both - Thank you Djordje!
I will let you know how I go!
Thanks again!
Chrissy Avramidis
