MrSoleil
Curved walls misbehave in 3D (while 2D is ok)
Anyone knows why the walls would behave like this in 3D?
The plan is OK, no problems there. Just the 3D. We have a blobby project and this is happening all over it.
Changing the curvatures of these walls sometimes help. But we don't want to change all the plans.
Thanks!
3 Replies 3
How far is your model from the Project Origin?
If it is a long way, this can cause problems.
Lingwisyer
Guru
Try adjusting the Intersection Priority of your curved walls and those interacting with them. I find this often happens with curved walls not trimming correctly, but can often be corrected by changing the order in which they trim to each other.
Ling.
MrSoleil
All the walls are curved and of the same composite so its can't be that.
If I change these curves it will connect better, seems to be a problem only when the curve isn't smooth. But we can't change the curves.
