ā2009-07-16 08:47 PM
ā2009-07-16 09:51 PM
ā2009-07-23 03:20 PM
ā2009-07-23 03:59 PM
Jesikuh123 wrote:If you make a profiled object with OBJECTiVE, you have a parameter to control the resolution of facetting for curves (refer to the attached image). The specified value is the maximum deviation from a true curve for any given face. If you set the value very low, it will almost indistinguishable from a curve but at the cost of a higher polygon count in the model.
I have a curve in a complex profile that I made.
When I See this curve in a section it is not curved anymore, it has turned into poly lines. If I go check the complex profile in the profile editor it is still curved. IS there a resolution i need to be changing somewhere?
ā2010-03-16 05:30 PM
ā2010-03-17 01:01 PM
another Moderator
ā2010-03-17 05:14 PM
ā2010-03-17 09:01 PM
ā2010-03-18 12:31 AM
ā2010-03-18 01:28 PM
