Custom Background for 2d windows?
I’ve got a question.
In 3D studio Max, we can use an image (*.jpg, *.bmp, etc) as a background surface to “trace” (by hand, etc- not a programming thing) things like, say a car blueprint.
Is there a way to do this in ArchiCAD?
I’ve got some interesting hand-drawn plans without scales or dimensions exactly (they’re small drawings) and I want to put them as the background while I work.
I know I can open them in photoshop and dimension them a bit or even make them into a texture for Archicad (say, to put on a wall or slab) but is there a way in the 2d window to have this as the background?
I’m still searching the forums; just looking for a quick solution if someone already knows it….
Thanks!
3 Replies 3
File -> External content -> Place external drawing would work for you
Eduardo Rolon
and read about "Virtual Trace" in the help files, it will be worth it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
David Maudlin
JP-Design:
The Figure Tool can import many common bit map file formats. Once imported, the image can be resized.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
