2013-07-24
07:59 PM
2023-05-26
11:17 AM
Rubia Torres
2013-07-24 08:13 PM
2013-07-24 08:22 PM
Matthew wrote:For some strange reason, the width is ok.
It appears that the unit you are using is sizing to the rough opening. The quick fix would be to make the unit 1 3/4" higher and (I assume) 3 1/2" wider.
2013-07-24 08:36 PM
2013-07-25 03:45 AM
2013-07-26 03:30 PM
Peter wrote:Even if the door is a non-custom panel, it has the same problem. It seems to be taking the threshold into account. If I put in a 6" thick threshold, the 6'8" door is now 6'-2" tall.
Does this happen if the door is a non-custom panel?
I notice your image is showing the Sill/Threshold reveal as 3/4" thick. Could this be the cause of the discrepancy?
2014-09-05 04:18 PM
2014-09-05 11:13 PM
