Carstenem
Custom Window shapes with Curtain Wall tool made easy - save as library part too
New quick coffee tip ! This weeks tip explains how to create custom window shapes, any shapes, with the curtain wall tool. I show you how to save the window into the ARCHICAD library to be used at any time.
Enjoy Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
3 Replies 3
Hmooslechner
Its seems to be more flexible, if you just create the wallhole alone and insert an extra curtainwall in the hole..
Erwin Edel
Only downside is that you can't schedule those along with the other windows. If you save them as windows, they will show up in schedule.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Carstenem
The schedule part is important yes and on top of this you can re-size the window a little bit to fit if needed. This won't work if you add the curtain wall separate into a wall hole, it then is a fixed size.
Carsten
www.asmtechbase.com
