2008-10-09
02:08 PM
2023-05-23
04:59 PM
Rubia Torres
2008-10-09 02:09 PM
2008-10-09 02:35 PM
2008-10-09 02:37 PM
2008-10-09 03:05 PM
2008-10-09 03:08 PM
vanden wrote:This is easy to do with OBJECTiVE. You can create a profiled object with the wavy edge you need, and then tilt it over to the angle you need with OBJECTiVE's 3D rotate tool. You can also cut the profiles to suit the context, e.g. the raked end in example 1 (attached image). The cross-section through the model is quite clean too (example 2). It is also possible to bend the boards to curves (example 3).
I am trying to produce some wavey edged boarding on the side of this bike shed, I have tryed several different techniques to achive the right effect all without sucsess. The problem is that i need the board to be at a slight angle from the vertical so that the boards will overlap.
2008-10-09 04:27 PM
2008-10-09 04:33 PM
2008-10-09 04:34 PM
2008-10-09 06:16 PM
