Custom edge settings
I have problems with options offered in settings after clicking on the edge.
For example, when I click to blue or green spots on the roof, I can access these options: https://www.dropbox.com/s/b2jee36sz0qiusb/archiacd%20edit%20options.JPG?dl=0,
but I saw, I could get some more of them, for example:https://www.dropbox.com/s/gq2j7ram8shbgn2/ARCHICAD_2017-04-04_09-40-02.png?dl=0
I don't know where to click, I can't find it.
Thank you!
9 Replies 9
David Maudlin
tjaša:
Your second screen shot shows options that are available when editing the ridge of a Multi-Plane Roof. Your first screen shot is of the options for editing the perimeter or pivot lines.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
no, the second screenshot is not mine (https://www.dropbox.com/s/gq2j7ram8shbgn2/ARCHICAD_2017-04-04_09-40-02.png?dl=0)
that's what I want to achieve, but don't know how.
BS T
Maybe there's a difference between complex roofs ...
I now noticed that the left one is editable, but the right one not:https://www.dropbox.com/s/vm9b1ufhs0...rimer.JPG?dl=0
I made all the roofs with the magic tool and now I want to edit them, why do I have that option just with a few?
The ridge editing palette appears for ridges only where the opposing pivot lines are parallel to each other. (i.e. the ridge is horizontal) Is it possible that you have a non-horizontal ridge?
Richard
AC26 (since AC6.0), Win10
oh yes, almost all roofs have non-horizontale ridges. I made all of them with magic wand roof tool, cuz all existing surrounding buildings doesn't have to be exact, also the dwg file I got wasn't.
Thank you, now I know what's the problem, will change all to morf and work on.
tjasaa wrote:
Or, you could just change them to single plane roofs (right-click on the multi-plane roofs) and edit them manually.
Richard
sorry, am not sure how exactly can I change them to single plan roof ...
Select the multi-plane roof, right-click, and from the context menu that appears, choose "Split into Single Plane Roofs"
Richard
oh thank you so much!
That's the answer I was looking for Perfect!
