Custom window in Cadimage?
I'm trying to create a window in using cadimage, however I can't seem to get it to look right. For instance, how do I add the 'internal;' framing that sits around the glazing? I've divided the window but the middle horizontal frame isn't correct. Also, how can I change the framing profile (see attached). The wall is 400mm thick and the window is 2000mm wide.
Thank You
1 REPLY 1
I do not think cadimage can achieve this, if I was making that window I would be making 9 windows to create the overall window and then use complex profile for the structure between.
