Cut Corner off Complex Profile Ceiling
henrysaxby
Hi everyone,
 I'm making a CAD model of a school building that has a lot of curves (this is just the beginning!) I have a ceiling that has a gently curve created using Complex Profiles, but it intersects with a curved wall. I would like to remove the section of the complex profile ceiling that sits outside the room, but I can't figure out how to do it. Any suggestions?
 Thanks in advance!
2 ACCEPTED SOLUTIONS
Rajesh Patil
This could be one possibility but could be suitable for visual comfort. In future while editing the elements you have to be alert.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Hmooslechner
You could use a shell instead of a profile - its bendable for some cases like this. Shells can be edited (cutout holes and borders)) in the groundfloor-view (top-view when rotated) and can have multi-skins as well.
the other way would be a big enough morph-body for an SEO - command - intersection.
Rajesh Patil
Rajesh Patil
Hmooslechner
