ā2006-01-05
02:03 PM
ā2023-05-23
03:32 PM
Rubia Torres
ā2006-01-06 02:35 AM
miker wrote:from memory a roof can have zero thickness
It would be ideal if i have an object like roof but with 0 thickness.
Thanx
ā2006-01-06 02:51 AM
ā2006-01-06 07:18 AM
Peter wrote:yep you are right
A roof can have zero thickness and can be used to trim a wall to roof
but if it has zero thickness it will not work as an operator in a SEO.
Peter Devlin
ā2006-01-08 09:27 PM
Djordje wrote:Good tip, Djordje. I was not even aware you could define a roof pitch in this way. I thought you had to calculate the angle and put it in the settings manually. Very good to know, thanks.
View the wall in 3D. Activate roof tool, single plane. Click on the two bottom ends of the wall, and one top. That will make a transparent triangle - that is your roof plane. Now click on four points to define the roof plane. Done.
The roof plane should be on "Cutter" or similar layer that should be hidden in all but the working layer combos.
Clear as mud?š
ā2006-01-09 03:45 PM
