Tom Krowka
Cut plane
I'm sort of confused with the new cut plane thing. I have cut plane set to 4 feet on a particular story. I have a window that is entirely above the four foot cut plane at eight feet. How do Iget it to show up.
Also, have some low windows below the four foot line. If I raise the cut plane to show the upper window, how do I get it to show the lower window in the floor plan?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
7 Replies 7
Doors and windows have a Floor Plan Display setting option called Symbolic. It shows the D/W in AC9-style independent of the FPCP.
IMO this is the best default setting for D/W. As you've seen, you can use Projected to hide a high window, without resorting to high walls and such.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Tom Krowka
Does not work for me. Still does not show the high windows above the cut plane.
[email protected]
www.walshkrowka.com
Aha, the wall also needs to be Symbolic, which means 'Own Story Only' as well.
James Murray
Rakela Raul
can i handle the cut plane horizontally ??
for example: on the 1st floor to an infinite depth but for the above floors just to to a depth of 12',,, is this possible??
sorry, wrong thinking...i was thinking about the 'section tool' and a "selectable" depth per floor
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
I find the cut planes confusing. period.
Laura Yanoviak
The FPCP is saved with each view, so it can be unique for each view. Thus, you can have two different views of your first story, and/or different FPCP for each individual story.
Rakela Raul
thx Laura
i can have a section per floor at the same location with
diff depth and put together in the Layout....
