2009-10-16 10:31 AM
2009-10-16 09:40 PM
2009-10-16 10:18 PM
2009-10-17 05:44 PM
nedostizni wrote:That object has parameters to the angle of the cut to the end - see the illustration to the left of the attached image.
I want to cut a part of my profiled sheet.
2009-10-20 09:53 AM
2009-10-20 10:00 AM
2009-10-21 12:58 PM
Barry wrote:thanks for the answer. If i have saw it well, the Objective add on is not free, and i can`t pay it, at least not right now.
Either create a slab the shape of what you want to cut away and use a Solid Element Operation to cut away the shhet or get Ralph's OBJECTiVE add-on.
I don't have it but it looks pretty darn good.
nedostizni wrote:also, when i remove the object that extrudes the plofiled sheet, the cutted part on the sheets gets back to the origin.
I tried using Solid Elements operations, and intersect my profiled sheet with the wall in a shape of arc, and then tried to extrude (just extrude, and with downwards, and upwards extrusion) but as i though so, i didn`t worked (it worked in a way that the part of the profiled sheet where it intesects the wall, was extruded, and i wanted to extrude it in that area plus the whole left part).
2009-10-22 01:12 AM
2009-10-22 05:30 AM
2009-10-22 05:34 AM
Barry wrote:good idea
The layer I use (as shown here) is also set to wire frame view.
Barry wrote:A known pain but I guess would be tricky to code.
But note this will have absolutely no effect to the 2D view.
The sheet will appear as it always did.
You will need to use a white or background coloured fill to cover it up.
