DISTRIBUTE ALONG CIRCLE
Not had to do this before, so may be basic question.
Tried all the things I could think of but so far no go.
What I want to do is array/distribute square objects (in this case columns) along the circle path to the divisions I have set up, in this case 12, (although they don't show in this screen capture).
I also want them to maintain the orientation to the center of circle.
Is this possible without having to set each one individually?
thanks
lec
Dwight
You can do it with objects in AC13, but not columns, yet.
But, it isn't so bad using the divisions trick.
Set divisions to 12 to get gravity nodes - placing is fairly quick.
Dwight Atkinson
Dwight
Duh - read it wrong.
Just use multiply, rotate.
See this for details.
Dwight Atkinson
Dwight
But you only need 11 copies, not 12.
Dwight Atkinson
