2014-12-04 10:50 PM
2014-12-04 11:15 PM
2014-12-05 01:40 AM
2014-12-05 01:43 AM
2014-12-05 04:47 AM
NCornia wrote:
Rob,
I recommend you link the DWG in using the XREF feature instead of the Drawing tool if you are referencing a live, open file. You will not get the error messages then. I will check with the team here to see if it is a known limitation with linking open DWG files as Drawings.
Best regards,
2014-12-05 06:58 AM
rob2218 wrote:Other way around.
Doesn't the xref insert feature do something different with the DWG layers? By inserting the DWG as a drag-n-dropped file....you have more layer control? Is that right?
2014-12-05 02:26 PM
2014-12-07 05:32 AM
