Default "Save As" Location by project instead of global loc?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2016-06-15 11:09 PM
‎2016-06-15
11:09 PM
I also work on multiple projects each day.
When I "save as" to make my backups, it always shows the last location that I used the "save as" command, regardless of the file I currently have open.
I would prefer it if ArchiCAD's "save as" function would recognize that I am using file "Project One" when I am working on "Project One," and "Project Two" when I'm working on "Project Two."
The reason I want this to happen is that I keep accidentally saving files in the last place I used the "save as" command regardless of the project, instead of the last place I used the "save as" command for this particular project.
Am I explaining this well?
Does anyone have a solution, or should I put this in the wishlist?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Madison WI
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-06-28 05:12 PM
‎2016-06-28
05:12 PM
Hi Gus
I think this is not so much an Archicad problem as one relating to your operating system.
I discovered, after moving to a Mac, that this is the case with all 'save as' operations - and it drove me mad, constantly searching for files that had gone awol.
In the old days of PCs, you used to 'log on' to a driver, or folder, and then all operations, "save", "open" or whatever, happened in that folder. Like so many things, progress seems to have resulted in a backwards step.
I'm afraid I don't know what the answer is, except to get used to it, and keep checking what your 'save as' path is before you press 'save'.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-06-28 05:32 PM
‎2016-06-28
05:32 PM
Time to buy Default Folder X
http://www.stclairsoft.com/DefaultFolderX/
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
