2005-10-30 06:21 PM
2005-10-30 06:22 PM
2005-10-30 09:50 PM
tsturm wrote:use the 'Select Duplicates...' command as you have correctly surmised: Tools>Add-on Manager... and load 'Check Duplicates Tool' from the 'Goodies' folder of your archiCAD installation . . .
Now we need to clean some part up there are ten lines in ONE spot. We just need the one line. How do we clean up fast?
2005-10-31 07:10 PM
2005-10-31 09:38 PM
tsturm wrote:i just tried it and found the same! a glaring bug that nobody has discovered before in my opinion. go ahead and report it with a vengeance! is it the same on your PC as it is with your mac?
Why does it not work on fills?
Any idea of the best way to clean house?
