Delete duplicates
KeesW
Here's a puzzle. When I look a model, the message box says that I have 1934 duplicate library parts. A very long list of items is shown. When I use Tools/Find or Tools/Delete duplicates it only finds, and deletes, 1. It doesn't matter if I select current level or whole project. Why doesn't 'find' and 'delete' do what it says?
KeesW
Cornelis (Kees) Wegman
cornelis wegman architects
8 REPLIES 8
Bruce
Your library loading report pertains to the library parts loaded - not necessarily used.
The delete duplicates pertains to duplicates used in the model itself.
To get rid of your 1934 duplicates unload all your libraries then load the basic ones (e.g. ArchiCAD library 9) until there are no missing library parts.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Do you have the same problem afetr restarting AC9?
I don't know what's the problem, but 2 months ago I have problem like this:
I have deleted 24 columns from existing 42 and than have selected all columns on the floor plan. It was written that I still have 42. The problem was solved only after restarting AC.
plz,keep your eyes on
coz you may delete two different object but only have the same name,so will
lose lib parts and the only error is same name
KeesW
Thanks for the advice.
So what is 'delete duplicates' supposed to do?
KeesW
Hello KeesW
'Delete duplicates' is supose to 'search and delete' duplicates on your file not on your lib.
For example same wall, with same layer, same color, same material in the same flor; etc.
For the duplicates in your library parts you need to treat them manually .
You can see this topic for more explanations. http://archicad-talk.graphisoft.com/viewtopic.php?t=6885 .
Hope this Helps
I had a look at the post and followed Steve Jepson's example. Took me the best part of an hour on one project.
This is a 'hot topic' as far as I've concerned, because we are working on a lot of projects which started under Acad 7 and contain library parts from 7, 8 and 9.
Steve asks if there is a 'better way to purge duplicate library parts without doing all this'.
It's a good question!
Erika Epstein
On the US tech support site
http://tr.graphisoftus.com/
there are downloadable pla versions of older libraries AC libraries ( 6.5, 7, 8.1 and . These allow you to load these older libraries at the same time as the current AC9 library without getting the thousands of duplicates in the load library dialogue.
Very useful.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Aussie John
Open the project, save as archive (making sure only library parts used in the project are saved).Close then open the archive and save the new library as a project library. Add new library part from your upto date main library
Cheers John
[/size]
