Deleting Unused Layer Combinations?
Are there any ways of knowing exactly which layer combinations are being used or not without having to go through all the view sets and checking manually?
We are able to do this for layers in the attribute manager since there is a column which puts a check mark next to layers being used. There is no check mark column for layer combinations (see attached images for reference.)
Any clever ways of purging unused layer combos
3 Replies 3
Also, does anyone know if this has changed in recent versions of ArchiCAD?
Laura Yanoviak
Still the same in AC15.
You could do a View List, with 'Layer Combination' as one of the ordered fields, although it won't tell you which layer combs are not being used.
(Related BUG - 'Renovation Filter' isn't available to add as a field in a View List in AC15!)
