Design Extra`s - Wall Accessories.....Where has it gone??
Does anyone know where wall accessories has gone in AC-15?? ....Hope it`s still there somewhere as it`s a great tool
In AC-14 it was under Design/Design Extra`s/Accessories/Wall Accessories.
5 Replies 5
Are you talking about the cadimage wall accessories.
If so, all cadimage stuff is now under the cadimage menu. Although if you have migrated your work environment from v14 they may not show up. But they should show up with the default work environment.
No, the wall accessories I am referring to was a standard feature in AC-14 & not related to cadimage.
the roof, wall and slab accessories have to be downloaded and installed;
click on the archicad 15 downloads item in the help menu and it will take you to where the accessories, and other add-ons, can be downloaded.
they also had to be downloaded and installed in previous versions but were referred to as 'goodies', i think.
Great work!!! - all sorted ....thanks mate!!
Steve Jepson
For me they were missing until I discovered that the Accessories Library is not in the ArchiCAD library. I had to load the Accessories Library separately.
Is there a way to get the wall framing components to be independent ?
We used to have an add-on called the object exploder for version 12.
Is there anything like that now for version 15?
