Eman
Deleting lines
Please I want a little advice about 'guide lines' that I draw with line feature and not with guide line feature (Alt+L). I want to know how I delete them all at once instead of deleting them one by one. I mean as the 'remove all guidelines' feature.
Here is a photo of an elevation drawing with lines.
http://www.fotothing.com/photos/659/6594d1a64327fc5136e6ed613b5ef183.jpg?ts=1548008411
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 Solution
Eduardo Rolon
Place all those lines in a specific layer, I use A-NPLT Construction Lines and then turn that layer off for that Layer Combination. If not you can use Find and Select to "grab" all of those lines provided that they are different from others either by line type or pen color and then you can delete them
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
2 Replies 2
Eduardo Rolon
AC29 US/INT -> AC08
Eman
Hi ejrolon,
I did not realize that, yes that is very easy and exactly what I wanted!
Thanks.
Eman / Draftsman
