Bruce
Deleting rogue layers
I have some layers in my projects (5 separate stages of the same project linked via mod files) that I simply can't purge.
This is what I've done:
- Opened the mod file so there are no sections, elevations, details or worksheets to confuse the matter
- Changed all object layers to ArchiCAD
- Turned on all layers and done find and select for elements on rogue layers on every story
- Made sure there aren't any hotlinks, xrefs or drawings linked into the file
- Opened everything in 3D and tried find and select again just in case there were objects hidden between view planes.
Nothing. I just can't purge them (I can delete them, but I don't like doing that).
Is there a way to run a report on a layer to see what's using it?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
12 Replies 12
Erwin Edel
Any layers specified in the DWG-translators perhaps? Running out of ideas here too, sadly.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Link
Definitely sounds like a hotlink module issue. It's very strange that stage 2 layers are appearing in stage 1, if you've never put any stage 2 info in there. You sure no one else has? What's your default master layer for hotlinked modules?
Link.
Bruce
The master hotlink layers are called "Import: Main.STGx" where 'x' is the stage number being referenced.
None of these layers are in DWG translators.
I even had one layer created by ArchiCAD called "Import: Main.STG2#2". Don't ask me how that one happened.
Anyhoo - I've deleted them now and it seems like I did cover all possible bases. It would be good to be able to run a layers report though.
Ta for all your help.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
