2005-01-11 12:51 PM
2005-01-11 02:49 PM
2005-01-11 03:45 PM
2005-01-11 03:45 PM
2005-01-11 04:34 PM
TomWaltz wrote:While it's hard to argue with this statement, one must really consider the project as a whole and everything from the desired result to its complexity. So...
My personal ideal is that if something only shows up in one drawing, draw it in 2D. If something shows up in multiple drawings, model it.
Krippahl wrote:Since you will be using ArchiCAD to communicate your intent as well as for problem solving sometimes having the existing building modeled can help the client understand what you are proposing and sometimes it can help a contractor as well. An example might be the picture attached which can be used to compare existing and new space or to let a contractor have a clearer idea of what needs to be removed. (demolition layer is set to show as wireframe in 3D)
Now, building it into the computer... You become intimate with everything about the building. This is great, because when you go to the next stage, which is trying out some solutions, you already have them pretty much nailed down.
2005-01-11 06:57 PM
cgorgas wrote:You probably don't need any tips on 2D methods for showning demo work but attached is a drawing with a squiggled custom line type used for the walls to be removed. This can also be used when you would like other parts of the drawing to look more hand-sketched.
I am fairly new to ArchiCAD. I am wondering how most people approach the problem of a remodel. Working in 2D it is very easy with 3D it seems that you would end up with a very confusing model. Any and all tips are appreciated.
Best regards - Chris
2005-01-12 02:41 AM
2005-01-12 01:19 PM
2005-01-12 01:31 PM
2005-01-12 02:01 PM
patricprz wrote:I would usually measure and build the model from my measurements. If the existing drawings are the construction set, then input your building model from the actual dimensions. I have found it useful to start my input from the structural drawings and then add the architectural walls. Closer to the way it would have been constructed and you can find and discrepancies from the architectural to the structural plans. If there are any you can be sure that the builder probably didn't find them until the structure was already in place.
I am working currently on a large project which is also as your americans call it "a remodel".
I was curious how you would best move the hand drawn existing building plans to CAD? Scan it in and trace over the existing drawings? Measure and draw? I am tring to establish 'best practice'.
