We value your input!
Detail Tool Problems
I am trying to get a simple detail tool callout to work on my plan. I have a stair which I am trying to show on enlarged plans at 1/4". This particular stair is rotated 15 degrees. When I go to draw the outline it will not rotate, however the detail in the new window is rotated. What can I do to correct this? It looks really stupid on the plan and seems to include areas that do not show on the detail.
I also have tried to use the link to existing detail portion of the tool and the box around the area disappears completely leaving me to wonder how effective is this tool? Has anybody created a detail bubble that works for them?
Thanks
Chris
4 REPLIES 4
Erika Epstein
1. Chose the correct "Geometry" method to draw the edges of the detail "bubble" as you would like them to appear on your plan or other view. If the detail bubble outline will not show as you would like it to, you can alway choose one of the detail markers that show just the detail marker and draft in a detail bubble as you would like it to show. The detail window when opened will not be affected.
Note that the "bounding box" will show but not print if that option is chosen under:
Options
Display Options
Detail Boundry: show/hide
2. The "Link to Detail Drawing" feature allows you to have one detail created in the file, for example a typical eave detail, and all other typical eave detail bubbles placed throughout the other drawings/views reference that original eave detail.
To do this, once you have a detail marker placed in the file, when you chose the option to "Link to Detail Drawing" a list pops up of all the placed details in that file and you chose which one you want it to link to.
If you also take advantage of the drawing and sheet number placeholders then in Plotmaker when you move the detail around either on the same layout or from one layout to another, all the EAVE detail and sheet placeholders will automatically update.
The user interface for this tool is a bit awkward, but play around with it and you will not only get the hang of it but I think you will be quite pleased with what it can do for you.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Link
I'm the first to admit that the detail doesn't work as one would expect!
I suggest playing with the settings shown in the attachment and checking your luck.
Link.
OK
we got the detail indicator to display properly on the plan and we have created a number of details. However when we run the rebuild from source view all of our dimensions disappear. Has anyone else experienced this? Is this normal? Seems counterproductive to me.
Is there any way around this without detaching the detail from the model?
any help would be appricappreciated
Eduardo Rolon
Since dims are dynamic/linked to the objects they refer, when you rebuild the detail the reference for the dim is gone and so is the dim line. The two solutions to this are:
1) use static dimensions for details
or
2) make a copy of the detail to one side and dimension that one. When you rebuild the detail then you incorporate the changes to the detail copy
I know it is not the best solution but the detail tool does not behave in the same way that sections/elevations do.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
