Detail marker clipping line
rjwilden
We seem to have lost the ability to stretch the Built in Detail marker rounded rectangular clipping line. I'm stuck with a box of 1 size and cant change it in any direction, and although old and tired my brain can remember that back in 10 I was able to do this . Is there a new way of doing this or has GS broken it.
Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Richard
In markers' settings, in general settings section, try "editable polygon" for working mode. You may have it set to "follow clipping polygon".
Edit: just realised its under Marker Geometry in Ac11
rjwilden
Thanks Stuart.
Ill have a look at it in the weekend
Richard.
Archicad V23:V24
rjwilden
I have sorted this problem out and thanks "LINK" for the answer.
You cant edit the detail marker boundary line unless the marker range is active .
editing your detail boundary by going to View> On-Screen View Options> Marker Range and make sure it is indented.
Richard
Archicad V23:V24
