‎2007-10-18
09:58 PM
‎2023-05-23
05:04 PM
Rubia Torres
‎2007-10-18 11:51 PM
Daniel wrote:I assume you're working with AC11, since the "Detail Boundary" Panel was available in AC10. The Detail Indicator_NCS was removed from the AC11 Library (but is available from the AC10 Subset library) so there may be some migration issues with this object?
Graphisoft has erroneously hidden the parameters to change the pen and line type for the actual bounding box that is defining the area of interest.
Daniel wrote:I haven't had time to look into it, but I can tell you that we still use a customized version of the Detail Indicator_NCS Marker, and have no problems referencing the detail and sheet number. I'll have to investigate to see if the Detail Boundary parameters are accessible....
Can anyone tell me how I can fix this marker so I have control over the boundry? Is there a special way to resave a marker object? I think I just used the "Save as" and only had object.gsm type to save out.
‎2007-10-18 11:53 PM
‎2007-10-19 12:06 AM
‎2007-10-19 12:16 AM
Karl wrote:What is the bug? The fact that there's no longer a Detail Boundary Panel, or the Marker is scripted wrong?
Not that it will make you feel any better, Daniel, but this bug was reported months ago and a fix was supposed to be in a library update. I guess that hasn't happened yet.😞
‎2007-10-19 01:59 AM
