2023-03-18 11:16 AM - last edited on 2023-05-09 03:04 PM by Rubia Torres
When I create a flat roof, and alter the angle in 3D, the change is reflected in the Roof Height and Pitch window.
But when I alter the gableheight of a gabled roof, using elevate ridges, it doesn't reflect the changes.
Bug or intended?
.Kamelite
2023-03-19 08:52 AM - edited 2023-03-19 08:53 AM
By 'flat' roof I assume you mean a single plane roof.
They only have one surface and therefore only one pitch.
Multi-plane roofs can have any number of surfaces and only show the original pitch as it was created.
In the settings (not info box) you will a warning to say there are multiple pitches.
If you click on a pivot line of a multi=plane roof and go to the 'Custom planes' option in the pet palette, you will see the custom pitch.
2023-03-22 08:15 AM
That makes sence. It never crossed my mind that I could do other things whith the gable than just elevate it!
.Kamelite
