Different concrete grade in Model and Composite...
I would like to differentiate the poured concrete to different grade.
The purpose is to have quantity according to different type of concrete grade at the end of the process.
How do I adjust the model and the composite?
Hopeful the model can be adjusted so I can differentiate the concrete in 3D.
Create separate composites with different fills and attach different materials (with different textures if you use texture images) to the slabs when you place them.
You can set up favourites to choose these quickly.
Then you should be able to schedule the different grades and they should appear different in 3D.
