2006-02-09 11:56 PM
2006-02-10 12:28 AM
2006-02-10 02:40 AM
2006-02-10 06:18 AM
2006-02-10 02:49 PM
Ben wrote:Not really. Unless you want all the same dimensions you show on 1/4" plans to show up on 1/16" plans, they need to be on a separate layer.
Hi guys
Since version 9, text (but not labels) can be either fixed or scaled. This should make this sort of layer set up redundant.
2006-02-10 04:25 PM
2006-02-10 05:23 PM
2006-02-10 06:34 PM
NeckoFromSarajevo wrote:As Barry mentioned, if you want elements drawn at one scale not to show at another, they will need to be on separate layers. Most people have a layer for "Text - 1:50" and "Text-1:500", that are part of a layer combination.
i just cant get this working.!!!
In Project map i draw 4 wall in 1:50, put dimensions and other stuff
I want to this 4 walls and other stuff put in a view set that i created but i want that to be in 1:500. So i put that in a view set in a new folder that i created. So its there. When i change 1:50 to 1:500 everything is changed, drawing in Project map and i view set. I dont want this 2 drawings to be linked. I want to draw something in drawing 1:500 that will not be in drawing with 1:50.
I want them to be seaprated and only then i will be able to do what i want. Is there way to unlink or not. Can anyone create little manual how to do that.
Is it possible to create drawing in View set that are not linked to Project map but i get them from Project map and there, in view set i will adjust them for ploting ???? !!!!!!
Plz Help, or i will explode!!!!!
NFS
