2007-05-11 12:38 AM - last edited on 2023-05-26 02:58 PM by Rubia Torres
2007-05-14 02:34 AM
Stress wrote:Yes most of my composites have an off set reference line, and this is good to know. Unfortunately in this case and most cases involving issues of truss bearing, seat-cuts in rafters and shear transfer detail from the roof diaphragm to the shear walls, the section cuts are limited vertically in such a way that the bottom of the walls is almost never in the view.
Jay:
Do you off set the walls reference line?
If so, you should be able to dimension ("Live" - circle symbol) to the reference line... as well as the outer skin. BUT, you'll only find theRef line nodeat the bottom of the wall.
