We value your input!
Project data & BIM
SOLVED!
Dimension elevation in schedules
Matador264
Hello,
I'm making a joinery list for a project. With Archicad's automatic tool I can display the ‘3D Back view’ of my elements. I see that it is possible to dimension them manually one by one but I would like to know if it is possible to do this automatically (I have nearly 50 different elements to dimension).
Thank you for the help.
1 ACCEPTED SOLUTION
Solution
Select an image and turn on the 'Add Automatic Dimensions' option.
It only gives overall dimensions.
If you want more you still have to add them manually.
1 REPLY 1
Solution
Setup info provided by author
