Dimensions don't show up over the hatch
Is there a way to put hatch with the window or white background behind the text. I have lightened the hatch and the dimension is still hard to read. Please help?!?
1 REPLY 1
Not sure if this is what you mean, but you can draw a fill box around the text, fill with white (or whatever colour you want) and use display order to bring it forward, or send it back; to bring it in front of the window, or put it behind the text, respectively.
HTH,
Daniel
