wall ends clean up
I've tried to use wall ends (...awful tool) but can do nothing with lines appearing in the elevations. The connection between wall-end and the wall is shawn with a line. And the same is for wall-ends above each other.
Is there any way to remove such lines without unlinking elevations.
3 Replies 3
If all else fails you can draw a white line over the intersection. this will cover it up.
TomWaltz
Tom's Patented Easy Way:
In the Wall End object, turn off the 3D Representation. Then it's just a 2D object.
Tom Waltz
yes! I've defeated it! It seems that I just used wrong type of wall end for my needs.
