Disappearing Beams
I have a file in which all the ceiling track (modeled as profiled beams) has vanished from the floor plan and I can't get it to show up at all on any story regardless of settings.
The file started out a bit strangely as an IFC from Revit which had no story at the project zero elevation. I figured it might be a problem but assumed I could straighten it out later.
Story 1 was at 118'-3" and stories 2-4 were at 16' floor to floor heights above. Below was a tunnel level at about 96'.
I have tried to correct it by revising the story settings and moving the ceiling track (beams) to other stories in 3D.
I have also tried all floor plan cut plane settings I can think of and all the different display settings for all stories, home story only etc, and outlines, projected with overhead, etc.
I also tried hotlinking an older version of the file into a newer one with no luck. I'll try a clean merge next but am not optimistic after the other failures.
So....
If anyone has any suggestions for what I may have missed I'd love to know.
The infamous renovation filters?
YAY! YIPPEE! THANKS! YAHOO!
I forgot all about that. Since I haven't figured out a way to used them for phased construction yet I haven't had any use for them.
