2010-03-19 06:53 PM
2010-03-23 12:23 AM
2010-03-23 04:26 PM
2010-03-23 04:42 PM
2010-03-23 05:10 PM
Laura wrote:They're electrical schematics. The zone stamps are there to assist reverse lookups from the schedule and to show coverage areas for fire equipment and emergency lighting mostly for permitting purposes. However the main geometry in drawings is there to guide the electrician who is actually installing the devices, and they won't care about the zone information at all, so the clarity of the schematic is paramount. Since a break in a line has a meaning, an artificial break created by layering causes confusion in the field.
Just out of curiosity -- why do you have so many elements that you want to display ABOVE the Zone Stamp? I can't think of a single instance where we would want the Zone Stamp obscured by anything.
2010-03-24 12:58 AM
2010-03-24 10:06 AM
2010-03-24 04:08 PM
Arcadia wrote:I know that Text and Dimensions brought to the top of the stack CANNOT be overlapped. Also, Bring to Front does not assign the element to a Display Order of 1, but brings it above all placed elements -- the opposite is true for Send to Back.
I don't think this issue has anything to do with the zones. I come across this problem quite often just working with 2d lines, fills and text. You would think that you could pull any object to the 'top' but sometimes it just won't go any higher even though clearly it is not on top. Also you would think that any new text or lines or whatever would automatically be placed on the top but this is often not the case.
2010-03-24 04:34 PM
Matthew wrote:Yeah this is exactly what we're looking for, I'll move to the overlay approach as a home rolled layering scheme. We're going to be reorganizing our workflow for the next project and this will likely work better for us anyway.
Sounds like a the prefect place to use the overlay approach. I have often seen the electrical schematics in black overlaid on a grayed out floor plan. Very easy to do in the layouts with the right pen sets.
2010-03-25 07:16 AM
Arcadia wrote:There is a ranking to which elements have priority. If you can't put a line on top of something else e.g.a slab, you have to first send the slab backward. The line or lower order element can't bump a higher ranked element out of place. the higher element must be moved first.
2010-03-25 10:51 AM
