2009-07-20
09:02 AM
2023-05-25
06:07 PM
Rubia Torres
2009-07-21 09:11 AM
2009-07-22 01:28 AM
2009-07-22 07:00 AM
laszlonagy wrote:Yes laszlo..flipping is working, but this means I have to always put the doors in a wrong way first (I have to remember always to place it opening to the other side) and then correct it , I mean its just not practical, so I was looking for any solution. copying attributes didn't even work !
So with Fllipping you achieve what you aim for, if I understand correctly.
Can't you just select all such Doors with Find &Select and Flip all of them in one step?
If they are on several Stories, you can do the Find & Select in the 3D Window.
2009-07-22 09:18 AM
2009-07-22 01:13 PM
adzik wrote:Adzik, Thats right, still the annoying part is there
It's kind of the same what you are doing right now but if you set the door opening direction to flipped in the door settings dialog then later (after placing it in plan) you don't have to change it.
Although you still have to click on the wrong place when placing the actual door.
2009-07-22 01:45 PM
2009-07-22 02:01 PM
