2018-02-02 01:04 PM - last edited on 2023-05-24 08:24 AM by Rubia Torres
Solved! Go to Solution.
2018-03-01 01:45 AM
shaneharman wrote:Walls place with complex profiles can be increased in height but can not be decreased.
So am I right in thinking once I store it as a complex profile I can use it as a wall type but the height of the wall type will be set as per the complex profile and not height adjustable ?
2018-02-02 01:43 PM
2018-02-05 04:09 AM
2018-02-06 05:14 PM
2018-02-23 11:47 AM
Barry wrote:Barry,
Or use a complex profile wall that combines the different wall types.
Then you have only one wall and the sill should cut it properly.
You can model the walls separately, select both then EDIT > REHAPE > MERGE WALLS.
This will create the complex profile for you and even swap it with the two walls.
2018-02-26 03:16 AM
shaneharman wrote:Yes this will merge any parallel walls into a single composite keeping their original materials.
Barry,
Apologies you have lost me purely as I was unaware you could do this ! (Self taught so probably loads I do not know) The ground floor wall and substructure walls are made up of two different composites so will this still work ?
2018-02-28 07:33 PM
2018-03-01 01:45 AM
2018-03-01 09:53 AM
